Mabou2
Flight distance : 811257 ft
diablo690 Posted at 2018-8-26 13:32
i have a problem updating my Ronin S firmware to v 1.3.0.20... the V 01. 02.0010 updated fine but after that the DJI PRO assistant 2 is just stuck on connect the USB.. i have uninstalled/install the software and device but still no luck... the is no error message on USB Serial Device (COM3) in the device manager... i am also aware of the usbser.sys driver and all that, but i can't find a solution please help me troubleshoot thank you!
I don't know if this helps or not. So this might just be a waste of your time to read. But when I connected my Ronin to my computer, I had the Ronin s completely turned off while plugging everything in, then I planned to turn the Ronin s on.
But after plugging in the cables (to my Mac Notebook), the battery grip went into a charging mode and I could not turn the Ronin on. after a few seconds I saw the (on-screen) USB cable graphic make its connection in Assistant 2.
I was able to upgrade my firmware without turning the Ronin s on.
So maybe you just need to shut the power down on the Ronin s, fire up Assistant 2, and make the USB connection to get the update to work?
ALSO, after installing the Ronin Pro Assistant, there is a driver installer that appears, it says it is only for Android, but I couldn't get anything to work on my Mac until I installed that driver.
