djiuser_arYtg8cijZYs
Austria
Hello,
since I updated to the latest version, the Balance Test reports (Yaw: Good, Roll: Excellent, Pitch: Excellent). I did no camera adjustments or movements while, before or after the update process. With the older firmware version I got all three balance properties on "Excellent".
I see on the last point of your release notes, you fixed something on the Balance Test status report for "Pan axes" and it says "tilt the ronin s sideways for correct results". So I assume the "Yaw:Good" stands for the "Pan axes" and "Good" is not the correct test result for me now because I did not tilt the ronin while performing the Balance Test.
So can you please give any hints what exactly has to be done to get the correct test result? Which side to tilt? What angle? Maybe a picture or tutorial video.
Many Thanks
S.Munar |
