BrilhasMuito
Flight distance : 3745554 ft
Brazil
DJI Tony Posted at 2018-7-19 08:57
Hi, thanks for the inquiry, I would like to clarify if the gimbal will response if you try to command it using the gimbal wheel? did you try to adjust the gimbal of your aircraft? When did you notice this issue? Did your aircraft experience and slight incident?
Its normal. You wont be able to go all the way up.
The upper section is a room the guimbal leaves for the camera to move when flying fast forward.
