Peejay1977
Flight distance : 123717 ft
I suspect to answer your question fully DJI would have to give you information relating to the way in which the RC "see's" the mobile devices and that is probably unlikely since they won't want people messing around with feeding the output of the RC into things other than a supported mobile device.
You can connect the RC to a PC with a micro-USB to USB A for purposes of updating the firmware using the DJI Assistant software, so at the very least the PC will recognise the controller, whether or not you can make that USB device available within the BlueStacks app is something I can't answer, but the simple answer is, connect your RC to your PC and it will recognise it, BUT, only if you have the DJI Assistant software installed as I believe it installs hardware drivers for the RC and the Mavic itself.
If you can get that information out of them I'd be very surprised, DJI aren't going to want to sanction you doing this, for multiple reasons. A simple Google search shows the information I've posted above, but you'll have to try it with BlueStacks and see if the emulated DJI GO app will pickup the RC or not as a passthrough USB device.
Perhaps I'm misunderstanding but I see several mentions of WiFi range, what has WiFi got to do with anything? If you're in RC mode then WiFi is irrelevant. Unless I've misunderstood something.
Also, the recording directly to your editing station, I'm not sure I understand, the app caches the video feed but I don't believe it's a fully quality copy, so can't see why you'd want to cache lower res footage when the good stuff is on the SD card.
