I bought brand new dji phantom 4 advanced, after update the firmware, i have problem with the gimbal tilt down around 70 degree, it should be stay at 90 degree
Hi. I am sorry that you are having issues with the gimbal of your new DJI Phantom 4 Advanced. Please try to calibrate the gimbal of your Drone. I will be posting the DJI Tutorial video on how to calibrate the gimbal properly.
DJI Stephen Posted at 2018-7-20 15:05
https://www.youtube.com/watch?v=lpkdUH0XE8g
1. When starting the aircraft, the camera makes a moves as the ghimbal is warming up. The camera gets its horizontal-front possition but after a few seconds a noise comes out from ghimbal and it lose its position making a tilt down.The camera aim (tilt) down a little bite (approximate 70degrees ) when it is suppossed to stay firm at 90degree (horizontaly)
2. When I fly the aircraft and I comand rotating to the left or right the camera has a tilt up and then slowly moves to the horizontal position.
3. I have tried again to auto calibrate the ghimbal but it gets stuck at 50% calibration process.
4. Brand new out of the Box, havent been fly before
5. AC Version 0128
I really need help, please!
Hi all,
I have similar issue with the gimbal.
I start the drone and the camera is just pointing down and moves a little bit forward like a centimeter and returns same position pointing down.
All that repeats forever and no calibration helps. Neither manual or auto.
I have reinstalled the app doesnt help.
Can anyone help me with that?
Many thanks
djiuser_75vMnYhiTyON Posted at 2018-7-20 19:38
Exactly the same issue! Need a solution from DJI. Seems like a software issue.
