Mavic Air instability issue
842 9 2018-7-21
RichInGa
Flight distance : 449344 ft
The Mavic air does this all the time for me and it's quite disturbing.  In this video all I did was do a right stick pan, and suddently the whole craft just dips to the left. This only happens for  a second, but again it does this all the time, and usually in the first few minutes of the flight.  Any Ideas?
2018-7-21
DJI Stephen
Hi. I am sorry that you are having this experience on your DJI Mavic Air. May I know if the Drone had a crash or a hard landing before?
2018-7-21
RichInGa
DJI Stephen Posted at 2018-7-21 09:25
Never had a crash or hard landing. It's in perfect shape.  I'll also add that there was a bit of wind but only about 5mph.
2018-7-21
RichInGa
Here is the first one that I posted above and then another that I had back on July 5th.
2018-7-21
nywrecker
Flight distance : 832421 ft
Were you in sport mode when when you panned?
The commands in sport mode are much more pronounced.
2018-7-21
RichInGa
nywrecker Posted at 2018-7-21 17:36
No... I rarely go into sport mode.
2018-7-21
S.D. Pilot
Flight distance : 10278435 ft
I was thinking the same b/c I get that kind of FPV wing-mode movement in S-mode but steady as can be in GPS mode.
2018-7-21
Optimus_Prime
Flight distance : 568704 ft
Vietnam
My very first Mavic Air also had this issue due to gimbal malfunction, every time i pan, tilt up or down while landing or taking off, it shaked. So i suggest that you should send for a check.
2018-7-21
RichInGa
UPDATE: I flew this several times after without an issue -- I started out in a VERY wooded area on both occasions, and I don't think I let it get a good GPS lock.  Watch the Satellite count!!
2018-8-25
Lucas775
Flight distance : 50642090 ft
RichInGa Posted at 2018-8-25 05:45
That is a rookie mistake, always have enough satellites before take off! glad you figured it out.
2018-8-25
