I use a Mavic Pro and normal goggles, first it worked, then the googles disconnected. If I press the connect button on the Mavic now, the RC disconnects.
Aardvark Posted at 2018-7-22 04:44
Pair RC to Mavic Pro. Then with RC off pair Goggles to Mavic Pro. Goggles will communicate with aircraft without RC.
Edit:- the 'linking' option is in the settings menu on Goggles.
Thanks a lot for your suggestions. The goggles do not connect either RC is on or off, RC connects but once I press the connection button RC shows disconnected.
Any further ideas?
Hello there. We apologize for the inconvenience. You may try to refresh the firmware of the goggles using DJI Assistant 2. You may refer to this tutorial:
DJI Wanda Posted at 2018-7-22 07:57
Hello there. We apologize for the inconvenience. You may try to refresh the firmware of the goggles using DJI Assistant 2. You may refer to this tutorial: https://www.youtube.com/watch?v=Crnjfe4ssdo
Yes, great, it was just the firmware. I have updated and now it works fine again.
Thank you all!
