kndll
Flight distance : 930161 ft
Bashy Posted at 5-5 20:32
The problem is that folks are using inferior leads, some leads are power only, no data, they will never work, the ones where you have to mess with the usb settings in the dev mode are just rubbish leads, the only thing you need to do to get the Tab S2 working is by NOT setting the DJI Go 4 app as default app, never set it, you ALWAYS want it to ask you if you want to launch the app. it also does not matter which way you turn on stuff except for the controller, that is always before the drone. if you have an issue see in the ac on the screen, unplug the use form the S2 and plug it back in, works every time. As a side note, you can set the app never to ask to save as default app, that does get annoying asking each time, so turn that off in the android settings under default apps i think it is.... PS i do not have to wait 15 seconds, i do not have to change MTP to RNDIS and i have 2 Tab S2's and both work just fine, dont ask why i have 2, i cannot answer on here ;)
which model of tab s2 ? 10 inch works , sm- t713 8inch will not |
