P3 car charger 12V
2333 17 2015-5-22
Dbonyad
Hi,
I'm looking for a car charger for the P3 -- 12V.
Does anyone know if I can use the first part of the cable from the Phantom 2 series car chargers and connect that to the Phantom 3 charger? Does this work with the wall chargers?
The best I can come up with so far is an inverter, but they waste a lot of energy!
Thanks.
Davood
2015-5-22
brianmlevy
Flight distance : 2441663 ft
I thought DJI did a car charger....
2015-5-22
Fulgerite
brianmlevy@me.c Posted at 2015-5-23 01:11
Not for P3.
2015-5-22
Fulgerite
Inverters don't waste that much.  A modern inverter is typically in the 90% efficiency range.  So you might suffer a 10% loss at most.  Not a big deal.
2015-5-22
Dbonyad
Does anyone know if you can use the first part of the phantom 2 car charger in the standard phantom 3 charger?
2015-5-22
digitaldave
Flight distance : 752917 ft
I ordered this Power Inverter out of a recommendation from www.phantomhelp.com They have not steered me wrong yet and the owner of this site is a member of this forum. I received it yesterday but haven't tried a charge yet. The unit is built very well. Will be doing my first charge this afternoon in the car. I can come back and report if you wish.
Here is the Inverter: http://smile.amazon.com/gp/produ ... 0?ie=UTF8&psc=1
2015-5-22
s_nyky.yahoo
digitaldave Posted at 2015-5-23 03:33
I ordered this Power Inverter out of a recommendation from www.phantomhelp.com They have not steered ...
Let me know how you like it and if it works well, might pick one up as well! Thanks
2015-5-22
bradleydraifing
You should look into getting a pure sine wave inverter if you're charging in the field and want to help maintain the longevity of your batteries. All of those cheaper inverters produce a modified wave or square wave which give out a lower voltage of 110v vs your home outlet at 120v. They produce a dirtier, more inconsistent current and when charging delicate electronics, such as lipo batteries with sensors in them, its definitely recommended to use pure sine wave. They will run you around 5 times the cost of the cheap-o ones but they'll last longer and so will your electronics.  I own a Samlex, they make quality pure sine inverters but there are other good options too.. good investment if you ask me
2015-5-22
bebbi
Monaco
bradleydraifing Posted at 2015-5-23 05:31
You should look into getting a pure sine wave inverter if you're charging in the field and want to h ...
agree bradleydraifing,
a inverter is not the best thing, but for the moment the only option as we all only have one battery..
I'm more concerned about people recharging the hot battery pack straight after flying,
you should wait around 15 mins to cool down the battery pack, high temperature can kill it.
2015-5-22
digitaldave
bebbi@fettabern Posted at 2015-5-23 06:30
a inverter is not the best thing, but for the moment the only option as we  ...
Thanks. I will take this under advisement. I knew about the cool battery from the P1.
2015-5-22
digitaldave
Hmm, you got me thinking. What about this one? http://smile.amazon.com/Samlex-- ... +sine+wave+inverter
Thanks in advance
2015-5-22
jon.jongodfrey
what's wrong with you guys, why don't you just take a spare battery or two?... Oh, no sorry, wait...... it's the P3... I'll get my coat... ;-)
2015-5-22
bradleydraifing
digitaldave Posted at 2015-5-23 07:30
Hmm, you got me thinking. What about this one? http://smile.amazon.com/Samlex--15S--12A-DC-AC-Inve ...
That one should be fine, I have the 300 but again, I can only, truly get 300 watts from it when I hardline it to my deep cycle marine battery.
2015-5-22
digitaldave
bradleydraifing Posted at 2015-5-23 09:03
That one should be fine, I have the 300 but again, I can only, truly get 300 watts from it when I  ...
Ah ok. Was wondering how much latency you get from a cigarette lighter. Thanks again for the info!
2015-5-22
digitaldave
jon.jongodfrey Posted at 2015-5-23 07:36
what's wrong with you guys, why don't you just take a spare battery or two?... Oh, no sorry, wait... ...
Yea I wish. With the car charger I can get maybe two sessions in the morning and then I'm done for the day. It's hit the rainy season here and winds are picking up too.
2015-5-22
leoamartinez
Flight distance : 1602986 ft
Dominican Republic
I have a question, i have a Chevy Tahoe 2015, it comes with an equipped 110v Outlet, do you think it works to connect the P3 oem wall charger and charge a battery?
2015-5-23
bradleydraifing
leoamartinez@gm Posted at 2015-5-23 22:36
I have a question, i have a Chevy Tahoe 2015, it comes with an equipped 110v Outlet, do you think  ...
The 110v outlet in your car is basically just a modified sine wave inverter tucked away under a panel in your car. Will it work? Yes it definitely will work. If you're going to be doing a lot of charging from DC power though, you should consider investing in a pure sine inverter. You may not notice a difference at first but the batts should last longer and the drone should perform better all in all on a cleaner current.
2015-5-23
leoamartinez
Dominican Republic
bradleydraifing Posted at 2015-5-23 23:12
The 110v outlet in your car is basically just a modified sine wave inverter tucked away under a pa ...
Thanks! Very explained answer!
2015-5-23
