DJI Tony
Hi, sorry for the incomplete resolution that was given to you in regards to your concern, for clarification when you're using a spark and MA, you have to have an OTG cable for you to connect the RC to the DJI goggles. Video transmission image quality might change from recording resolution. Please see the details below for references.
* When the video is recorded at 4K, the highest video transmission resolution is 720p/30;
* When the video is recorded at 2.7K, video transmission resolution tops out at 1080p/30;
*When the video is recorded at 1080p or below, depending on whether the frame rate is higher than 30fps or lower than 30fps, the max video transmission resolution will be 720p/60fps or 1080p/30fps, respectively.
Please don't hesitate to reach us for further assistance. |
