Lightbridge Ground Station Power Connector
1280 3 2015-5-22
richardhuison
Flight distance : 54455 ft
Hi Folks,
I want to make up a lead to power my LB. Does anyone know the connector type as i cant find it anywhere?
Regards
Rich
2015-5-22
smee56
Flight distance : 18655 ft
You are not the first nor will be the last to spend hours searching the internet for a compatible part. Many people have had to buy a second charger and cut the cord. Alternatively you could put in a quick disconnect inline with the cord.
2015-5-22
richardhuison
smee56@gmail.co Posted at 2015-5-23 08:03
You are not the first nor will be the last to spend hours searching the internet for a compatible pa ...
Seems crazy that the part isn't sold
2015-5-22
Mark97564
Flight distance : 2067749 ft
I'm pretty sure the typical barrel connector is all you need..  You just have to find one with a huge center hole, about 5.5mm to 6.5mm would be my best guess..  But it is a barrel plug for sure, I'm just not sure of the size
2015-5-30
