spark have proplem
1592 24 2018-7-23
oil
Flight distance : 72897 ft
my drone have problem is aircraft status : no signal , aircraft encoder error , no image gut gimbal enable what happen???
2018-7-23
oil
Thailand
No, I'm the only one who is experiencing problems. As well as my friends, this is also a problem.
2018-7-23
DJI Paladin
Flight distance : 318 ft
Sorry for the trouble. Can you please provide a screenshot on the error message that you are receiving?
2018-7-24
Alexey Batalov
Flight distance : 21105262 ft
First try downgrading your app to version 4.2.12 from apkmirror. It usually helps. Its that the latest 4.2.21 and 4.2.20 versions from play market, they require a device with minimum 4gb of ram (its better to have 6gb of ram)
Its different for ios.
Safe Flying;)
2018-7-24
oil
Thailand
DJI Paladin Posted at 2018-7-24 01:52
status = ! Aircraft Encoder Error(0x800000)
contact dji support if this error persists after restarting
help me pls
2018-7-24
oil
Thailand
2018-7-24
oil
Thailand
Alexey Batalov Posted at 2018-7-24 02:18
Safe Flying;)
How do I downgrade an application? I do not understand and how it will work.
2018-7-24
Zagoni Attila
Flight distance : 86722 ft
Romania
Hello!
I have absolutelly the same problem, i had a slight crash (touched some leaves and landed in grass), not even a scratch on the drone, but it was requesting software update imediatelly, for the drone and for the controller, after that, same error message, no picture and battery info.
Drone flies well, gps and telemetry data ok, gimbal is working, front avoidance works.
2018-7-24
DMX_MT
Malta
Safe Flying;)
For Version v4.2.12 -
https://www.apkmirror.com/apk/dj ... o-4-4-2-12-release/
or
For Version v4.1.15 -
https://www.apkmirror.com/apk/dj ... droid-apk-download/
Both are very stable. Let me know how it goes Mate.
2018-7-24
oil
Thailand
Zagoni Attila Posted at 2018-7-24 03:07
Hello!
I've updated both, but I'm still on the aircraft encoder error.
2018-7-24
Alexey Batalov
Im afraid that it might be a hardware issue if downgrading did not help...
2018-7-24
pmshop
Flight distance : 8073271 ft
I hate to say, any error like that needs to be sent in to service
2018-7-24
oil
Thailand
Alexey Batalov Posted at 2018-7-24 06:03
I think so
2018-7-24
oil
Thailand
pmshop Posted at 2018-7-24 06:06
I want to know what happened. How to fix it.
2018-7-24
oil
Thailand
DMX_MT Posted at 2018-7-24 03:10
I'll try it.
2018-7-24
oil
Thailand
admin
Help me find a solution. I want to use my drone
2018-7-24
pmshop
oil Posted at 2018-7-24 19:34
Manufacturer defect
Send it into service
2018-7-24
DJI Paladin
oil Posted at 2018-7-24 19:42
admin
I suggest sending the drone back in for further evaluation if you still got this error on the app after doing some troubleshooting like rebooting the drone, restoring factory defaults and firmware upgrade. Kindly contact our support team to start up a case using this link : (https://www.dji.com/support?site=brandsite&from=nav). Thanks for understanding.
2018-7-25
genewSpark
oil Posted at 2018-7-23 22:20
My Spark Flew away after 11 seconds of flight in a completely unobstructed and remote place.  At 500 feet away the Drone dropped reception to the controller and just flew away at 35 MPH never to be seen again. It could have flew into a highway traffic, kids in a park, path of an airplane. DJI looked at the flight data and said because it was in ATTI mode it was totally my fault. I feel this is ridiculous. They refuse to answer these questions:
1) Even thought it was in ATTI why did it loose connection to my controller in a remote area with no RF interference or physical obstructions?
2) There are audible warnings about taking off, landing, low battery, etc. but if you are at such a risk of  losing your Drone when unknowing it is in ATTI mode, why is there not a similar warning?
3) The area I was at had STRONG GPS signal which I tested, why will they not answer my question why the failure of the GPS was not the true problem. Search the GPS issues with Spark and see how many have had iGPS issues!
4) When the Drone lost connectivity to the controller, why did it not stop and hover as they said it should have done? I could have retrieved it had this happened.
I believe DJI should replace my Drone for 3 reasons:
a) GPS failure
b) Drone did not stop and hover when losing connectivity (thus could result in very dangerous consequences). Two DJI agents said it should have stopped by design.
c)  Inadequate warnings when flying in a dangerous condition they call ATTI mode
I look forward to DJI answering these points
2018-8-1
oil
Thailand
genewSpark Posted at 2018-8-1 07:47
Oh, look how bad it is, in your case dji not responsible?
2018-8-2
oil
Thailand
DJI Paladin Posted at 2018-7-25 01:58
I just want to know how to fix it. And why it is so inspected and corrected I have a desire to play Dron soon.
2018-8-2
S-e-ven
Flight distance : 5922034 ft
Thailand
So you still haven't send it back via your dealer?
If it need to go to DJI (Hongkong for Thailand), it will need some time, anyway.
So you better get it into the shop and claim warranty.
Lucky for you, in your profil you seem to have more options for the waiting time!
2018-8-2
S-e-ven
Thailand
You should open your own topic, methinks!
2018-8-2
Zagoni Attila
Romania
  Similar issue in here- seems that somebody found the solution (on thread's end), it was a cable with wires touching each other
2018-8-7
oil
Thailand
Zagoni Attila Posted at 2018-8-7 03:58
It's similar but my spark
2018-9-10
