fjmaffei
Geebax Posted at 2018-7-24 16:07
I suspect you have Sandisk cards, not Scandisk? The one in the controller does not matter, it is not used for storing anything, the one in the aircraft is the important one. Which one stops recording? Exactly what type is the card in the aircraft? A photo of it would help. The problem you are raising is most times caused by the card in the aircraft. The first thing to try is to format the card in the aircraft using the DJI Go App video settings.
Thank you! I have updated the firmware 3 days ago, will verify the correct sandisk, and format new.
So the default video clip storage is in the Drone....do I need to change anything in the DJI App to use as primary? |
