sphere panorama image sequence
1003 3 2018-7-24
m4jp
Flight distance : 1228780 ft
Does anyone know in what order the image sequence are taken using the sphere panorama with an MP. I know there are 34 images and would like to know the order they are taken (as in facing front-bottom, then up 30 degrees vertical, then another 30 degrees 2 more times, then rotate to the right and what horizonal & veritcal angle?) Are the images taken always in this order?
Thanks for the info in advance...
2018-7-24
gnirtS
Flight distance : 5712575 ft
Take one and find out?
FWIW my MP always takes them in the same order
2018-7-24
Nick Lansley
Flight distance : 144951 ft
The best thing to do is actually to do this inside a large room such as your living room. Let the Mavic hover mid-room looking towards the window, then get it to take the 360. You can then immediately see the order it took the 34 photos as you recognise parts of your room from each photo.
2018-7-24
m4jp
Nick Lansley Posted at 2018-7-24 10:25
Thanks Nick. I'll try that. Just wondering if anyone knew already.
2018-7-24
