I see the gimbal with my S7
1378 8 2018-7-24
fanseda2ffc0
Hello everybody !
I just acquired my Osmo Mobile 2 that I use with my S7. Small problem, we see the gimbal on the right of the screen, which is very annoying. I can not find the solution for that.
Thank you in advance !
2018-7-24
DJI Tony
Hi, sorry for the trouble that it caused, unfortunately, this is due to a hardware limitation, however, you can move your phone a little bit so that you can get rid the motor of the Osmo mobile 2.
2018-7-24
marvinivram
My S7 is compatible normally, so I do not understand how this is possible. I saw a video of galaxy s7 without we see the gimbal.
ex: https://youtu.be/eXwH1PZBS9M
2018-7-24
jacksonnai
move the phone a bit to the side
2018-7-25
DJI Wanda
marvinivram Posted at 2018-7-24 14:02
Hello there. Sorry for the late response. We already forwarded this concern to our engineers. We'll let you know once we got an answer.
2018-8-1
CptDayDreamer
DJI Wanda Posted at 2018-8-1 03:10
Hello. Had the same problem with my S7 and now also with my S9. Is this a engineering problem of some devices or what? I mean some people pull it right into the position it should be and have no Gimbal in the video. And I have it with both devices. Please help us.
2018-10-4
Optimus_Prime
Flight distance : 568704 ft
Vietnam
In my case, i try to put phone further from the end. It solve the problem.
2018-10-6
djiuser_eNZsxL7RdVNY
Norway
Hi, I'm using a samsung s7 and osmomobile 2 with the dji go program. Most appears to work well except the posibility to switch between front and back camera, and the slow motion selection doesn't appear on the screen.
Doesn't this options work with the s7 and the dji go program? I've seen people use this options on youtube, but it's maybe iphone being used?
2019-2-17
Frank11ert
Hi Optimus_Prime, i'm curious now your moved your phone didn't this create other issues? I have the same issues (sometimes) with my S8, if I remove the backcover it's showing the gimball less (probably because the camera is more upfront).
However it noticed when I move my S8 to the left (to avoid the gimball in the shots) that it creates other problems:
1. The gimball is less stabilized (of course you can change this, but it's hard to put it back on exactly the same place everytime), so I won't be balanced when removing the phone and putting it back in the osmo 2
2. The phone has less grip and it's moving more, which is visable when walking or doing hyperlapse (even if you move like a ninja).
2019-2-20
