Remote Controller Signal Weak
15438 19 2018-7-24
Jejc Pro
i have a phantom 3 professional, (Remote controller signal weak) this  message appeared on the top middle side of the screen, i tried linking  it by pressing the button for 2 seconds using a pen but nothing happens. The remote controller continues to bleep and the red light contiinues to blink on the aircraft near the button I held in attempt to link the aircraft, yet the drone is showing the same message. Help Please. Thank you.
2018-7-24
DJI Natalia
Hi. Thanks for reaching out DJI Forum. I just want to make sure you are doing the right steps to re-link your RC to your AC. Please see the attached link below for video tutorial. Also, make sure that your firmware is updated. Thank you.
2018-7-24
Jejc Pro
DJI Natalia Posted at 2018-7-24 14:11
https://www.youtube.com/watch?v=zVOJnUidcUk
No this still did not work
2018-7-24
DJI Wanda
Jejc Pro Posted at 2018-7-24 18:24
Hello there. Sorry for the late response. Can you send a screenshot showing the error? Did you also try to adjust the antenna?
2018-7-25
Jejc Pro
DJI Wanda Posted at 2018-7-25 04:24
2018-7-25
Jejc Pro
Yes and nothing works. It seems like at setup by DJI.
2018-7-25
DJI Wanda
Jejc Pro Posted at 2018-7-25 09:46
I see. Please try to reset the remote controller by pressing C1, C2, and Shutter buttons. Turn off and then turn on the remote controller, link the remote controller and aircraft again, and check whether the image transmission restores.
2018-7-25
Jejc Pro
DJI Wanda Posted at 2018-7-25 09:51
No it did not work
2018-7-26
Jejc Pro
No it did not work please help
2018-7-26
Jejc Pro
========== 2014.01.01 00:00:11 remo-con disconnect======
Packet: P3X_FW_V01.09.0060.bin
Upgrading ...
Result: Success.
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2014.01.01 00:00:12 remo-con disconnect======
Upgrading ...
Result: Success.
Result: Abort.
Packet: P3X_FW_V01.11.0020.bin
Upgrading ...
Result: Success.
Result: Abort.
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
========== 2014.01.01 00:00:13 remo-con disconnect======
Upgrading ...
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
2018-7-26
DJI Wanda
Jejc Pro Posted at 2018-7-26 04:26
Upgrading ...
If that's the case, we highly suggest sending the drone for data analysis. You may start up a case online: https://repair.dji.com.
2018-7-26
Jejc Pro
DJI Wanda Posted at 2018-7-26 04:55
Do you know how much that will cost? It was working just fine before the update.
2018-7-26
DJI Wanda
Jejc Pro Posted at 2018-7-26 07:11
That will depend on the analysis of our repair team.
2018-7-26
fans88662db5
I am experiencing the same issue. After I hold the two buttons and toggle the camera wheel, the LED does not turn blue - remains red. Light next to sync button on drone just blinks red and green
2018-7-26
DJI Natalia
fans88662db5 Posted at 2018-7-26 11:01
Hi. We do really apologize for the inconvenience that this caused you. If that's the case, we highly recommend you to send it in for repair so we can analyze your drone. Thank you.
2018-7-26
Jejc Pro
DJI Wanda Posted at 2018-7-26 07:58
Ok I sent it in ........fingers crossed
2018-7-27
DJI Wanda
Jejc Pro Posted at 2018-7-27 04:26
Alright. Let us know if you still need any help.
2018-7-29
Jake Christensen
Very frustrated. Having same issue. This is a $1200 paperweight.
2019-9-16
djiuser_J0cDUHLgyVTR
Poland
Witam posiadam Phantom 3 profesjonal po włączeniu dioda na pilocie święci na zielono ale odlecę 500 m i wyskakuje błąd remote controler signal weak mogę wiedzieć dlaczego,kiedy to wyskoczy traci podgląd na telefon i po chwili deon wraca ale raz odlece na killmetr raz na 200 m i wyskakuję za pomoc dziękuję
2020-3-17
Geebax
djiuser_J0cDUHLgyVTR Posted at 3-17 14:32
Not the best translation, but:
Hi, I have a Phantom 3 professional after turning on the diode on the remote saints green but I fly away 500 m error pops up remote controler signal weak I can know why, when it pops up I lose my preview on the phone and after a while the deon returns but once I fly to killmetr once in 200 m and I jump out for help thank you
2020-3-17
