silverarrow66
Flight distance : 3888314 ft
Wachtberger Posted at 2018-7-25 14:31
Ok, you might have noticed that the number of responses to your post is rather limited, although usually incidents reported as yours attract a lot of attention. The reason for that lack of interest might indeed be what you have done with this flight, which was doing great damage to all of us other drone pilots by being totally reckless and illegal in flying that far out at night over urban area far beyond VLOS. There is no excuse for that, sorry to say it so frankly. If you had just hovered above your head for a nice night shot, I am sure that most of us would pardon you. But certainly not for what you have done, sorry again.
Nevertheless let me give you a short summary of what else has led to your incident and how it could have been easily avoided, just because it might help other pilots to avoid highly dangerous situations:
First of all your video does not impress me at all. It was taken in high wind, not to say a storm and you have had plenty of warnings before that happening which you simply ignored.
Allright, allow me to address some things...
First off, Thanks for your reply.
I understand and admit that me flying out that far was risky, and definitely not the smartest idea in the book, and that's on me. so consider this a lesson learned the hard way I guess.
After take off, I had moved myself on top of a hill where I could (barely) still see the led's. While this does not really justify flying 3000+ feet away, I thought it should be noted.
Through out the flight, I found wind to be no issue (up untill the incident) At ground level there was a very light breeze, and I noticed no performance variation with the mavic at that time. From what little I could make out in the video, and the live feed, there were no indications of stong wind (like trees moving and bending) . On the other hand, it was dark, and nothing could be made out well. So I'm still struggling to believe this was caused by wind.
The reason why the flight record stops is because DJI go crashed, when this happens in my experience, it creates a new flight log when the app is reopened, and the flight is resumed
I stayed at 3,766 feet. I did not move the craft to 4,571 feet. That was done by eather wind, or what ever issue my craft incountered.
Looking back over my logs, I noticed there was a motor current error that I simply did not notice on the screen while I was flying before this took place.If I had seen it, I would have brought it back asap, but I didn't, and that's my fault. Could this have anything to do with this situation?
I interrupted the RTH at 7m11s because I initially thought it was a issue with my craft, and thlutho that bringing it home manually would be better than letting a aircraft that had a issue fly itself home.
I put too much trust into my aircraft, and I shouldn't have. I'll make an effort to ensure this doesn't happen in the future
