MAVIC_AIR_HOT_PIXEL_in 720p, 1080p, 2.7k (60fps,...)
1353 5 2018-7-25
Chris_designer
Flight distance : 24813 ft
Greece
Hi!
A week ago i bough the mavic air.  What i noticed is that in a very dark place and in certain settings, there is a white (hot) pixel.
It is appears only in 720p, 1080p, 2.7k at frame rates of 60fps, 50fps and  48fps (up to 1000 iso).
I read that two other people had the same problem. I did all the upgrades, reset camera, etc but the problem was not solved.
After that i sent it back to the store to replace it and now i'm awaiting a new one.
I'm not sure if is that normal and i would like to know if anyone knows something about that issue.
If the new one has the same problem i do not know what to do because it is not clear if is than happens to all drones.
It is strange because in all resollutions at frame 24fps, 30fps and 120fps(1080) there in no any problem.
Probably it is a firmware problem...
2018-7-25
Aardvark
Flight distance : 384432 ft
You will likely get some hot pixels on anything but the very highest grade imaging chips when pushed to the limits.
2018-7-25
Chris_designer
Greece
Aardvark Posted at 2018-7-25 05:06
Thank you for your feedback!
If anyone has done the same test, i would appreciate
every report.
2018-7-25
Chris_designer
Greece
every report.
2018-7-25
Aardvark
"I'm not sure if is that normal and i would like to know if anyone knows something about that issue"
I would say quite normal:- There's a nice article Here which gives good explanation as to why hot pixels happen.
2018-7-25
Chris_designer
Greece
Aardvark Posted at 2018-7-25 05:50
thank you a lot for your time!
2018-7-25
