Purpose of Phantom 3 USB slot
10995 12 2015-5-22
sofagbem
What exactly is the function of the USB slot on the Phantom 3 body?
2015-5-22
mike
Flight distance : 228255 ft
You can transfer photos/data between the memory card and your computer. Some people use it to copy the firmware to their memory card.
www.PhantomHelp.com
Find the latest must-haves, fixes, mods, how-tos, guides, and accessories for your Phantom.
Phantoms in stock and ready to ship worldwide! (see availability)
2015-5-22
sofagbem
I am referring to the Phantom body USB slot that was used on earlier Phantoms to update firmware.
2015-5-22
digitaldave
Flight distance : 752917 ft
sofagbem Posted at 2015-5-23 11:59
Yes what Mike said
2015-5-22
Tahoe_Ed
Flight distance : 2605 ft
You can use it to access the Flight Data Logs on the P3.
2015-5-22
aburkefl
Flight distance : 78612 ft
You and Mike are referring to a different USB slot. The USB slot on the gimbal is used to transfer photos and video to your PC/Mac. It is also used for firmware updates.
The "other" USB port is on the front of the craft - under a little rubberized flap. At the moment, it is used only to capture flight log data. That flight log data can apparently only be read by DJI at the moment.
2015-5-23
sofagbem
aburkefl@gmail. Posted at 2015-5-23 19:14
You and Mike are referring to a different USB slot. The USB slot on the gimbal is used to transfer ...
Thank you.
I wonder why it was not used to update firmware and avoid the gymnastics of microSD insert and remove.
2015-5-23
Total
Flight distance : 336480 ft
Now I never remove the sd card , just connect to the computer with the usb on the camera .  Connect the cable then power on the P3 .  A folder will open up in My computer ..
2015-5-23
digitaldave
sofagbem Posted at 2015-5-24 10:31
Thank you.
I wonder why it was not used to update firmware and avoid the gymnastics of microSD in ...
Opps you are correct. I forgot about that one on the body. Sorry for any confusion...!
2015-5-24
Vaupell
Flight distance : 198392 ft
Denmark
Was wondering if i can hook something up that can be controlled from my controller, maybe a FPV cam, looking forward, while my main cam is fliming downward.
I always fly within "visual range" but i often photograph VERY close to objects, and often find my self moving around a lot instead of flying,
just to see if i can get closer etc. because the camera is pointing downward.  So i really consider "Retrofitting" my P3P with a FPV cam, and adding a
small lcd screen on my controller for that.
Kinda hoping i could utilize that extra USB port in some manor ;)
2015-7-11
Fulgerite
There are two USB ports on the Phantom 3.
1. The USB port on the camera is used to transfer video files.
2. The Port on the body of the Phantom 3 is used to access the flight data recorder.  it is very helpful after a flight or crash to diagnose what went wrong.
2015-7-11
Isaac
I am using a Mac, when I plug in the "Body" USB to my computer no driver shows up?  I did have a "Home" return failure to where I had to fight the craft back and had to crash it, so I would be very interested to see where it thought it was supposed to go...
2015-8-19
Chad America
digitaldave Posted at 2015-5-22 20:51
Yes what Mike said
Yes, what aburkefl@gmail.com said
2023-12-12
