HedgeTrimmer
Late Wed, after outside temperatures had cooled down to 83 deg F, sun had just set, and CrystalSky, RC, and Mavic Pro P had cooled down to inside temp of 72 deg F - went back outside for a test flight. After prepping system for launch, took off. No Live view video problem.
Tried inducing problem with rapid camera panning so there was lots of scene changes, that had to be processed for transmitting, transmitted, received, and processed for display on CrystalSky. Flew all around, with CrystalSky getting very warm, but still no Live view video problem.
Jumping forward...
Today, around 4:45 PM, sun still up and bright, with an outside temperature of 87 deg F, took CrystalSky, RC, and Mavic Pro from inside temp of 72 deg F outside for test flight. Kept CrystalSky shaded as much as possible while powering up Mavic Pro, get GO-4 active, and RC powered up and connected. Few minutes went by while verifiying GPS Sats, Compass, and RTH. Checked Live view video feed was working and clear, along with checking camera focus. CrystalSky showed outside case temp of 97 deg F.
Took off, hardly got any distance in air and away from take off point and Live View started pixelation-smearing-blurring problem! Tried a few camera movements and rotations of Mavic Pro, but Live view appeared frozen. Quickly verified both RC antennas were aimed towards drone. Finally, changed GO-4 App view, went to CrystalSky settings menu, then back to GO-4, and Live view was now working and clear.
Flew around for sometime without any further Live view problems. During last part of flight, outside case of CrystalSky showed temp of 123 deg F.
What ever is causing the Live view pixelation-smearing-blurring problem does not appear to be associated with warm or hot temperatures.
