Stopping the motors in air
6139 23 2018-7-26
Polet999
Flight distance : 352359 ft
User manual of P4P on the page 59 described "Stop the Motors" Method 2
When aircraft has landing, push & hold the left stick down. The motors will stop after 3 sec.
Did somebody have a problem during the flight "Push & hold the left stick down" that motor shut down?
2018-7-26
Anokadrone
Flight distance : 58327 ft
I have never had the guts to try it.  Why...did you?   Sounds like a good way to splatter your drone.
2018-7-26
andy10
Flight distance : 4585692 ft
I think that after you do that then you have a problem.
Who with common sense would push stick down and hold it for a 3 sec just to check out if it works?
Alternatively you can push the left stick down to a inner corner and push RTH simultaneously. This is for an extreme emergency only as you will destroy your AC that way.
I remember one or two cases on this forum where they did that just for a test and then they can managed to restart the motors and save the AC. But that was predesigned in advance.
This works well when the AC is on the ground and should be working up in the air too. But I can hardly imagine the situation at which I will be forced to do that.
2018-7-26
Aardvark
Flight distance : 384432 ft
Left stick full down will not stop the motors when in flight and descending, it will stop the motors three seconds after the aircraft has stopped descending. In other words it must be stationary before left stick full down stops motors.
As you are probably aware there is another command to shut motors down in flight, which I believe can also be disabled now in DJI Go 4.
2018-7-26
andy10
I think that you want to know if somebody had the situation when he/she must stop the motors.
2018-7-26
Uschi’s Phantom
As I recall the default in Go 4 to stop motors in flight is to fully push the left stick down and to the right while simultaneously holding the RTH button on the remote.  I have disabled that in my Go 4 app settings, though.
2018-7-26
Eric13
Flight distance : 13982031 ft
Try it out. Just make sure you are high enough. 200m recommended.
Watch this after 1:10 minutes:
2018-7-26
Hellsgate
Flight distance : 1991555 ft
I believe stopping the motors and restarting them is posible mid flight but you need to be at a sufficient altitude that you can restart the motors in time before the drone smashes into the ground.
Im not sure how the drone would react in this situation as it would most likely be tumbling down to earth and may behave erratically after motor restart.
Ive not seen or heard of anyone try this but in theory the logic is sound.
I dont think the op's question is about doing it on purpose tho.
Holding left stick only down during flight will give a controlled decent only once the drone has stopped its decent and remains stationary for 3 seconds will the motors shut down.
2018-7-26
Polet999
Anokadrone Posted at 2018-7-26 09:12
I brought it up for discussion on the forum because DJI’s user manual (p.59) only described that push left steak down to stop the motor when drone landed or as an emergency situation but any way on the ground, however not specified to the users how dangerous do this during the flight.
Why it’s important? DJI cutoff your ability to use all range of joystick movement during the flight, without any scare to move to the ‘shutoff motors zone”.
It will be great if DJI in the next software update leave only CSC (combination Stick Command) to stop motors.
2018-7-26
Hellsgate
Polet999 Posted at 2018-7-26 12:51
Holding left stick down during flight will NOT stop the motors.
The motors will only stop once the drone has landed
2018-7-26
Polet999
andy10 Posted at 2018-7-26 09:29
Per my conversation with DJI’s technician he assured me that I can move left stick in all range down without any problem during the flight.
That is why I asking if somebody I reality did this maneuver?
2018-7-26
Hellsgate
We all do it on every flight when descending
2018-7-26
Hellsgate
Have you tried dji flight sim? Its very basic but the sim drone will react in the exact same manner as the real one without the fear of breaking something.
2018-7-26
Hellsgate
The only possible way barring a malfunction or flat battery for the motors to stop mid flight is by performing a csc function. This should never be performed mid flight unless in an emergency situation.
Holding the left stick only down during flight will not stop the motors.
2018-7-26
Polet999
Hellsgate Posted at 2018-7-26 12:59
I destroyed my P3P to use left joystick all range of movement during the flight, that why I am so carefully with  P4P. When DJI announce model P4P in NY in 2017, I spoke with DJI rep. & he introduced  CSC command. It’s great, but why DJI leave also left stick stop motors? Even in emergency situation I’ll able use CSC.
As you can see everybody who responding to my question afraid or very inconvenience to use full range of left stick during the flight.
2018-7-26
Hellsgate
Polet999 Posted at 2018-7-26 13:24
I and many others always use full range of left stick during flight there is nothing that can happen to the p4p by using the full range of the left stick.
2018-7-26
Hellsgate
Using full range of left stick on the p4p will not shut down the motors during flight
2018-7-26
Polet999
andy10 Posted at 2018-7-26 09:35
No.  I don’t want play game to stop motors during the flight.
DJI states that use full range of left stick movement in flight it's safely.
My Q if somebody did this?
2018-7-26
Hellsgate
I suggest you read the manual thoroughly then once you finish read it again.
2018-7-26
Polet999
Aardvark Posted at 2018-7-26 09:29
2018-7-26
Polet999
Hellsgate Posted at 2018-7-26 13:31
Again, thank you so much for your response. I'll try.
2018-7-26
Aardvark
Polet999 Posted at 2018-7-26 13:37
I use left stick full down on my P4 & Mavic Pro without issue. On the P3 the 'CSC' (Combined Stick Command) was both sticks down and in to centre, or outwards. This was changed on the P4 to left stick down and centre + RTH button, because too many people were causing accidental shut downs.
Page 60 in the P4P Manual tells you that the P4P process for stopping motors in flight is same as P4, left stick down and centre AND push RTH button at same time. As I said even this can be disabled in DJI Go 4.
2018-7-26
Polet999
Polet999 Posted at 2018-7-26 13:52
I tested drone on simulator, then move Up & down by one hand & simultaneously push  left bottom.
Motors only stop when drone came to stationary position.
Then I tested outside, left stick working as described in manual.
I mislead myself after lost my P3P, & thought that cause of pushing Left stick full down.
Now I understood that happens  of malfunction  drone, not of my steering.
Many thanks to all who responded to my question
2018-7-27
Labroides
Flight distance : 9991457 ft
Polet999 Posted at 2018-7-27 15:02
Left stick down is the normal method of descending.
You can safely hold the left stick full down in flight and the motors won't stop until after the Phantom has landed and can't descend any further.
2018-7-27
