downgrade is done from assistant 2, log on to it as you did to upgrade, there should be a list of previous firmwares, click the one below the current one and see if it will flash. DJI do sometimes state you can’t go back to old firmware and if this is the case start a help ticket with DJI.
We're sorry to read the troubles. Please kindly connect with DJI Assistant 2 and refresh the firmware to see whether it helps. If still no luck, I'm afraid that you may consider sending the unit in for diagnosis.
ricci2 Posted at 2018-7-26 23:33
I dont have the option to downgrade. Only upgrade. ??
Maybe a need an older version of the assistant app but there isn't one available to download?
Hello, Just curious as to what upgrade you were doing? The last upgrade I saw for the M600 was, Aircraft Firmware - V 1.0.1.66 (04-17-2018), at the time is used DJI Assistant 2, V 1.1.7. Was there a newer release? I had no issues with that past upgrade on both of my M600 Pro's.
Taz Flyer Posted at 2018-7-27 07:22
Thanks,
The FW I upgraded to was V1.00.01.66 and Assistant V1.2.4.
I have no other options on the Firmware page apart from the current one. No option to roll back.
Does anyone have an other version of Assistant i can download and try?
I just checked my PC, I am running DJI Assistant 2, V1.2.3, and that is the version I used for the last update. I don't know if you can get an 'older' version of this application. I would open a case with support, and get their take on what to do next.
Regijean Posted at 2018-7-27 11:32
DJI Assistant 2 Version 1.2.4 requires that you agree to authorize share information to enable activation, firmware etc.
ESC errors went away for about a week and the all of a sudden it went nuts and crashed. As it was about to hit the deck i looked at the iPad and saw an ESC error.
