Ronin-S and Nikon D850 Focus wheel not working
5158 13 2018-7-27
SeaReid75
Flight distance : 25781 ft
I just received my Ronin-S yesterday.  I have tried several Ronin-s approved Nikon lens and while the record button on the Ronin activates focus and start/stop record, the focus wheel does not change focus.  I have tried Manual, Aperture priority, continues and single autofocus.  Nothing seems to be doing the trick.  I appreciate any feedback from the community.
2018-7-27
Hi SeaReid75, sorry for the difficulties on pulling focus, have you updated Ronin-S to the latest version? To pull focus with Ronin-S, please set the lens focus mode to M/A, and make sure the camera focus mode is set to AF.
2018-7-28
SeaReid75
running the current firmware update as of 7/28/18
2018-7-28
Volg.in
Flight distance : 8143 ft
United Arab Emirates
DJI Mindy Posted at 2018-7-28 00:19
I want to buy D850 also, is it really not works ? Maybe I need to sell my Ronis S before purchase D850 ? DJI what do say ?
2018-7-30
ToscanaDrone
Flight distance : 13833304 ft
I have Ronin-S and with the Nikon D850 (and the latest firmware) works perfectly (focus wheel, autofocus, shoot button).
2018-7-30
Volg.in Posted at 2018-7-30 04:52
Hi Volg.in, no worries,  Pull Focus is available for Nikon D850, please check the compatible list. GTScreenshot_20180731_204122.png
2018-7-31
Istrian
Flight distance : 2051860 ft
Croatia
I have problem too with pull focus on D850. Ronin and camera updated to the latest firmware. Led on focus wheel is steady green ( before firmware update it was blinking red) but the camera doesn't react at all on focus wheel. Shutter button and autofocuc works, but wheel is dead. Tried with 2 different supported lenses. Any suggestions?
2018-8-2
Sibehwushei
Flight distance : 7083 ft
Singapore
Hi guys need help!
i jus bought the Ronin s and D850. i updated to firmware 1.5 , managed to balance. i can take video and photo but can’t  pull focus on my 24-70 f2.8 n 14-24 f2.8
is there anything i did wrong?
appreciate any advice! thank!
2018-11-6
fansbda03177
Flight distance : 166739 ft
Mine is the same, i have nikon d850 firmware 1.03 and supported lenses 14-24 f2.8G ED and 24-70 F2.8G ED, and ronin is 1.07 something or the latest and focus pull wheel led is green but not working. PLS HELP DJI!!!
2019-1-12
fansbda03177 Posted at 1-12 21:13
Hi there, may I verify if you have set the lens focus mode to M/A and make sure the camera focus mode is set to AF?
2019-1-13
fanse3d398e2
DJI Mindy Posted at 1-13 23:54
Mindy, my Z mount 24-70mm lens has only M and A (no MA), what should I do?
ML
2019-2-1
djiuser_7cns7tjPC6lB
I am also Having problems getting the focus wheel to work. Are tamron lenses not compatible with the Ronin S ? if not then i have just wasted nearly £700. Surely the Ronin only needs to be compatible with the camera and not the lens as the camera have its own auto focus motor.
2019-7-18
rennab
fit you ever figure out this issue? I have the same camera and lens and I cannot figure it out for the life of me. DJI says check with Nikon. Nikon says check with DJI
2020-6-2
djiuser_KAG3bbIomqxA
Hi DJI i have a D850 with a Tamron SP 24-70mm F/2.8 Di VC USD G2 on my ronin s connected with the cord and recording works just fine but the focus wheel does not
I have tried all different possibilities with camera and lens being on M and AF,  the green light is on the focus wheel but still no response.
Can you help with this at all?
2021-3-26
