cdnorris
Dear Cathy,
While I appreciate your advice, this issue is not one that is simply solved by educating the user. I'm well versed in gimbal use, and the heat and battery drain an unbalanced unit can produce. The heat generated by this motor should not happen in any circumstance with this type of product - well balanced or not. It is defective and DJI should cover the warranty repair as such. Like the original poster, the tilt motor on my unit was too hot to touch. |
