Ronin S Centering Pan Offset
1271 6 2018-7-27
jmrfoto
Flight distance : 77257 ft
My new Ronin-S has a several degree offset from physical center when the gimbal is centered.  It's a few degrees to the left.  Anyone know how to correct for that offset in the  app?
2018-7-27
Hi jmrfoto, please check if all three axes have been balanced properly, then try the Auto Tune and the system calibration. If the issue persists, may I have the picture of the Ronin-S from ahead? Thank you.
2018-7-28
jmrfoto
DJI Mindy Posted at 2018-7-28 01:28
I did all of this multiple times and to no avail - I still have the slight pan offest to the right...
2018-7-28
HakimSG
Singapore
Hi DJI Mindy, I'm experiencing the same issue at the moment. Are there other ways to troubleshoot this after balancing properly and calibrating it?
2018-7-30
DJI-Paul
Flight distance : 41159547 ft
We plan to add a feature allowing you to set the center position in the next app update.
2018-8-1
Hi all, the post in 5# is from our engineers, please refer to it, thank you.
2018-8-1
user38b69f7f41
Flight distance : 100971 ft
Bulgaria
Hope to add "center position" feature because i've the same issue!
2018-8-18
