Force Pro connection to Ronin 2
7253 14 2018-7-27
GFORCE Aus
I can't get my Force Pro to connect to the Ronin 2
It has successfully bonded to the wireless and I have cable connected to the power input on the head but nothing comes up in the top bar of the Force Pro
2018-7-27
User101
Any luck? Having the same issue
2018-8-5
Flo the Pirate
Austria
just got my force pro delivered ... works fine (latest firmware on ronin 2)  beside heavy horizon drift and not being able to get the latest firmware installed on the force pro.
what´s your status ? did you get it working properly ?
2018-8-31
ssddee
Argentina
Same problem. At one point he walked, but now he does not connect anymore. Does someone know how to solve this problem?
2018-9-9
LUMINARIO
Flight distance : 169925 ft
Have you tried using DJI ASSISTANT app on computer to check firmware on all systems? Sometimes each piece of gear esp when binding needs to be updated to latest firmware or it does NOT bind. Had that issue with my Ronin 2 RC
2018-9-9
ssddee
Argentina
Hi, yes, update everything with the DJI ASSISTANT. Well connect the Dji Force Pro with the Ronin 2 but not connect the 3. Dji Wireless, Dji Force Pro and Dji Ronin 2. I also managed to connect the Dji Force Pro with the Wireless, but not with Ronin 2.
2018-9-10
UTMonty
Israel
Hi,
Same problem here: the Wireless Receiver is linked with the Force Pro - but nothing happens...
BTW I can bind the ForcePro directly to the Ronin 2 (without the Wireless Receiver), but the Ronin pops up a message advising to use the Wireless Receiver.
So, the Force Pro is OK, Only the connection between the Wireless Receiver and the Ronin 2 is problematic.
All devices are on the latest versions...
2018-10-11
djiuser_pugfjhQBgif9
Hi after connecting the forcepro with Ronin 2 it worked fine for 3 days. Now tilt is not working. Any update
2018-10-22
Thomas Joke
HI,
I have exactly the same problem between the wireless and the Ronin (https://forum.dji.com/thread-180632-1-1.html).
You find a solution ?
Thanks for your help !
2019-2-7
Thomas Joke
UTMonty Posted at 2018-10-11 01:55
Hi,
HI,
2019-2-7
fansaefdefc4
Turkey
i have the same connection problem, any solutions? Also lots of drift Dji pls fix your expensive machine !!
2019-3-30
colorbox
India
I cant update my wireless receiver.
2019-7-22
fansb103d4a3
Morocco
Drift problem solution is ‘ Use it lying down ’
2020-2-12
djiuser_0koRAJXGFdTE
Indonesia
Saya selalu mengalami drift ketika terhubung ke force pro
2020-8-5
Indonesia
2020-8-5
