Aardvark
Flight distance : 384432 ft
As EdM suggested in post number 2, you need to switch on all, and with your RC connected to a device running DJI Go 4 (you will have signed on at home when it was first installed) wait until the aircraft says 'ready to fly'. Then unplug USB from RC and connect RC to Goggles, that should remove the imposed 30m altitude and 50m radius limitation when using the Goggles.
Edit:- With latest version of DJI Go 4 you are prompted to sign onto account now when it is run for the first time (and consequently if you chose to log out again, or update).
