QuickShots issue
509 2 2018-7-28
SBasso
Malta
I've done several tests and I realize two things regarding the QuickShots.
  • The cache file always has distortion on the color.
(No matter where I am, my distance to the MA)
- The version on SD card is perfect.
2. I do not have the option to set up the direction, hight or any extra function from the Quickshot.
Is there any reason for it?
Everytime is something new or something not fully operating.
I do have android & it's listed on recommend devices.
I do have the latest version app & FW
I do have problems due to .400
I did reset the drone as factory swttings
I
Any further suggestion?
Thanks
2018-7-28
DJI Natalia
Hi. I'm sorry for the inconvenience that this caused you. In regards on your first question, have you tried to uninstall and reinstall your DJI Go 4 app?  You may also watch this video tutorial for Quickshot guide. Thank you.
2018-7-28
GuLe
Flight distance : 1233757 ft
Hey,
I have a question about the DRONIE quickshot. Never had issues with it (MA since may). I used it lately and noticed the speed went very slow of the mavic air. Normally it goes with 3m/s but now only 1m/s. Also when de dronie is finished it should come back. It does, but the horizontal speed is only 0.5m/s and the drone decends faster. So at a point the drone is already floating 5m above the ground when its still 100m away and horizontal speed is practically 0.
Can try to put the older firmware on it, maybe latstest firmware is causing it? Other quickshots seems to be fine
Anyone else experiencing this??
2018-10-26
