djiuser_lRLRS9uExnsp
Flight distance : 2817034 ft
Czechia
Phantomski Posted at 2018-7-28 11:27
i just did a full reset of the RC (c1/c2/rec/iso/power) - took me down to rc 1.9.2 version and things do look better, will report as I test more...
EDIT1
no dice, 1.9.2 worked 2 times, then stopped... What is weird, when i power on the drone, even with radio off, the led on the camera NEVER even blinks.. however sometimes when it goes green, everything is ok... I reseated all the cabling,m and find it hard to believe it's not a firmware issue - but... Can someone with P3A confirm what the status of gimbal LED is when powering on without the radio turned on?
Hello, could you be so kind and describe the procedure of full reset of the RC (c1/c2/rec/iso/power)? There are buttons: c1, c2, start/stop, playback, shutter. Thank you, Jaroslav. |
