Philips screws on v2 Phantom 2 - check this out
3595 20 2014-11-3
Daryl.Watkins
Flight distance : 3741171 ft
Just got my new v2 P2 and the included phillips screwdriver doesnt fit the screws on the outer corner of each leg. How in the world is this possible? It's their screw and their screwdriver! The flat side doesnt fit it either. Just an FYI.
2014-11-3
Gobokinetic
Its a free screwdriver used to tie a ball of string too incase of a fly away
2014-11-3
rod
New Zealand
Gobokinetic Posted at 2014-11-4 05:24
You got a screwdriver??? bwaaaaah! I've missed out again!
2014-11-3
mixstreme
rod@voxvideopro Posted at 2014-11-4 06:50
Another example of innovation at its best....{:2_40:}
2014-11-5
jim269
I got a hammer with mine.....
2014-11-5
rod
New Zealand
Hi Jim, you didn't really need a hammer, it will fly itself into the ground at high speed at some point all on its own, and save you the trouble of whacking it!
2014-11-5
jim269
LOLOLOLOL !
2014-11-5
DJI-Sophie
China
Hi Daryl, would you please kindly send us a picture about this problem? Thanks.
2014-11-9
flipside
I have the same problem. The screwdriver is 3mm. The screw on the end the arm is a smaller than 3mm.  What kind of picture do you want Sophie?  Could you tell me what size screwdriver is required for that screw? Thanks.
2014-11-21
whyley27
you will need a phillips 00 screwdriver for the ones at the end of the arms
2014-11-21
flipside
OK. Thanks for your help.
2014-11-21
DJI-JS
Flight distance : 48940 ft
the screw driver is for mounting the mobile device holder and the Wifi extender to the Tx, not for taking the craft apart.
2014-11-21
Daryl.Watkins.g
Thanks but I have a P2 non-vision.
2015-2-26
kleake.rapfire
Flight distance : 1361040 ft
DJI-JS  If it is for mounting the Wi-Fi extender and mobile device holder to the Tx, why did I get one with my Phantom 2 non-vision since it doesn't have these devices?  And why would they give you the allen wrench to take the other screws out of the case, but then you still can't take it apart because of these screws?  Seems like a bad excuse to me, because my screwdriver doesn't fit those either, but luckily I had a couple nearby that do fit it.  That screwdriver could be really handy if it actually fit any of the screws on the machine.
2015-2-26
Capt. Bill
whyley27@sky.co Posted at 2014-11-22 02:20
And a good quality one too. Cheap ones from the thrift or drugstore will not always work
2015-2-26
jonathan.statt
kleake.rapfire Posted at 2015-2-27 05:56
DJI-JS  If it is for mounting the Wi-Fi extender and mobile device holder to the Tx, why did I get o ...
You don't get the screwdriver with the Vision+ or Vision. You only get it with the lower models. On the Vision models the device holder and extender are already mounted so there is no need for a screwdriver at all.
2015-2-27
trailtec
jonathan.statt Posted at 2015-2-27 17:51
You don't get the screwdriver with the Vision+ or Vision. You only get it with the lower models. O ...
Nope, mine were not mounted. I needed to mount both the range extender and the phone holder. Mind you the screwdriver I got fits the only body screws I had to remove, the ones that hold the propguards.
2015-2-27
jonathan.statt
trailtec@dodo.c Posted at 2015-2-27 18:43
Nope, mine were not mounted. I needed to mount both the range extender and the phone holder. Mind  ...
They must have changed that at some point then, because my P2V+ V3 came with the controller fully assembled with holder and WiFi module
2015-2-27
crash1sttime
Flight distance : 1047503 ft
Oh yes you do (I feel a panto moment coming on), I got a nice green rubber handled one with a reversible bit with my Vision unit, and the holder and extender weren't mounted.
2015-2-27
gnixon2015
my p2v non-plus came (at christmas) with a screwdriver and the phone holder and such were not mounted on the metal bar.
2015-2-27
jonathan.statt
Okay, my mistake. I assumed the plus and non-plus were the same. As I mentioned earlier, my plus came with a controller already fully assembled and no screwdriver
2015-2-27
