FantomDK
Denmark
Yes, that is normal.
I'm not sure - did you change the speed of the clip? Or is it the speed of the original clip?
As such, I don't see anything wrong with the image, also I don't see any "jello" which is what we suspected you were talking about.
I personally shoot in 30 fps (max for the 4K) to get it as smooth as possible. Some choose 25 to conform with TV or 24 to conform with movies/cinema/film. If you want to do that sort of fast movement, you could consider doing 1080P60 fps in which case it would be much more smooth. But 30 pretty much is the standard - and if you remember to use smooth movements you will get smooth video, also at 30 fps (or 25 or 24 for that matter - but why not go for 30 when it is for Internet and home-use?). Set your Phantom to "NTSC" and then you can choose the 30 etc. framerates.
Because you rotate/yaw, there is also a bit of change in exposure, which isn't so pretty. This is why you should consider using Manual (the button under the shutter button in the Pilot app). Also you can click the AE-lock (little text-"button" top right). In Manual you set the ISO (100 in normal day conditions) and set the Shutter speed until you don't see too much overexposure (make sure you have enabled Overexposure Warning in the Camera settings - these show as "zebra-stripes" on the screen). It is important not to have too much of the image overexposed because that will be 100% white with no detail (can't do anything with it in your editor). But some zebra stripes are inevitable and okay, like the sun or reflections. If you try to get rid of them all, the image will become too dark.
Here is the kicker; there is a problem setting the shutter speed high (which the camera will do automatically in Auto mode (when not in Manual mode)). Having a very high shutter speed (200+) for video has the consequence that each frame becomes very sharp. Now, that sounds good, right? In stills it is. But in video, it isn't. Because in video we want some natural motion blur when there is a lot of fast movement in the image like when you rotate/yaw like in the video. In fact, the general rule of thumb is, to have a shutterspeed of about twice the framerate. So if you do 30 fps, it would be good to have a shutter speed close to 60 (lower and it will become quite blurry when there is movement, higher it will get stuttery/choppy like in your video).
The reason the camera does a high shutterspeed is because it uses it to control the amount of light that comes to the sensor. It only opens a short while to get enough light, if it is a bright day (or just daylight). What we can do to control this is to add an ND-filter (neutral density). This is like sunglasses for our camera, it is a grey filter that cuts out a part of the light so the camera can run at a slower shutter speed without getting overexposed. This has the benefit of adding some very much needed motion blur - and can also aid in problems with "jello" that we talked about. There are no official ND-filters available for the P3 yet, but there are some solutions, including cutting out filters yourself from GEL-sheets. It is not perfect, but it can help in certain situations. I could possibly cut you some filters from the sheets I have.
In general, you should really try to make very very slow camera movement. If you want to use/show the video, spinning that fast is a big no-no (unless you're going for that effect) It is really about slow slow smooth smooth movement. It can help to lower the EXPO of the sticks so they don't move so fast when you just move them a little bit. This also goes for the gimbal-speed - it really helps to slow that down significantly from the standard setting which is way too fast for smooth gimbal up-and-down movement.
It is a good lesson to look at some of the nice looking aerial drone videos and notice what other people do. Notice that usually they dont turn around at all. They just go in one direction for a smooth flight - and then cut to another clip where they also don't yaw ("look around").
I know it got a little long-winded, but I hope you can glean something useful from my experiences.
Edit: I forgot to metion that some of the artifacts you see are due to compression. This is also normal. It gets worse when uploaded to YouTube where it is recompressed even further. Again, fast movement is the enemy. Especially in large areas of the same texture with tiny details - like that parking lot and especially grassy fields, tall grass etc.
