Push mode noise/weak Smoothtrack after firmware update
2581 15 2018-7-29
Marty_Smith
Flight distance : 21768 ft
New Zealand
Whining motor noise in medium/fast pans only when in Push Mode. Smoothtrack is very soft in Push Mode also. Pan motor is late to engage and settles abrubtly.
This has only happened since the latest firmware update.
No settings apart from Smoothtrack changed anything.
Gimbal reset performed. Calibrated. Autotuned.
Just a Mini and Ultra Prime on there.
Videos:
Ignore creaking. Just Ready Rig noise
Push Pan off, Smoothtrack on
Push Pan on, Smoothtrack on
Close up Push Pan on
Ideas welcome!
Thanks
2018-7-29
DJI Susan
Hi Marty, sorry for the late response. Just to verify, does the issue remain if disable the SmoothTrack? Alternatively, you may adjust the pan values of speed and accelerated speed higher in Smoothtrack to see whether it helps.
2018-7-30
Marty_Smith
DJI Susan Posted at 2018-7-30 03:23
Hi Susan,
Smoothtrack OFF there is no problem.
Smooth ON there is no problem.
Push Pan ON is the problem. No adjustments to other values made a difference to the noise with Push Pan  ON.
Smoothtrack also becomes weak... late and abrupt to engage and release (regardless of deadband/smoothing setting)
Thanks
2018-7-31
DJI Susan
Marty_Smith Posted at 2018-7-31 17:11
Hi Susan,
Thanks for getting back to us. We'll double check with our engineers and come back later.
2018-8-3
DJI Susan
Hi Susan,
Hi Marty, sorry for disturbing you, may I have the screenshot of your settings in SmoothTrack?
2018-8-6
Marty_Smith
New Zealand
DJI Susan Posted at 2018-8-6 02:09
Hi Susan,
I'll won't be using the Ronin on a job for a couple of weeks. Therefore I won't have it near a camera to build.
Is the logfile of any use? Is it possible to generate that and send to you?
2018-8-6
DJI Susan
Marty_Smith Posted at 2018-8-6 03:00
Hi Susan,
Of course, you may send us the log file to check. Currently, from the current info we collected, it is more like the issue of settings, so we would like to check and see whether this can be reproduced at our end. Appreciate your understanding.
2018-8-8
edmoore
Flight distance : 598150 ft
Hi Susan, just to report I am having an identical issue on my R2. Only an issue since I updated til latest firmware.
2018-8-16
Marty_Smith
New Zealand
edmoore Posted at 2018-8-16 02:42
Ed, do you still have those settings you quoted on FB to help them replicate?
2018-8-16
edmoore
DJI Susan Posted at 2018-8-8 05:00
Hey Susan - just seeing if there is any update on this issue? Very very obvious this is related to Push Pan and Push Tilt - if I have either on, I get motor noise on both motors when operating normally in smoothtrack. Turn off Push mode immediately stops the noise.
2018-8-28
DJI Susan
edmoore Posted at 2018-8-28 12:48
Hi edmoore, sorry for the late response as I just read your comment. Could you send us your settings of  Smoothtrack? I'll forward to our engineers for further review.
2018-8-30
FLMLLC
I just updated and having same issue. Has this ben adressed/fixed?
2018-11-4
Marty_Smith
New Zealand
FLMLLC Posted at 11-4 17:51
I have spoken toDJI. They've found the problem. Fix in January firmware. I've seen no problem with push tilt.
2018-11-25
Thomas Joke
I have the same issue like many others !
We all need a new firmware ASAP !
When ?
2019-1-17
Hi Marty_Smith and all, we sincerely apologize for the trouble with Ronin 2, it is recommended to turn off the Push Mode and we will get it optimized via the firmware update, please wait patiently, thank you.
2019-1-25
YVRoninUser
DJI Mindy Posted at 2019-1-25 00:34
Hello DJI Mindy,
I have tried to update to the most recent firmware (Jan '21, version 1.7), and I am still experiencing the noise issues exactly as this user documented years ago.  Supposedly it was resolved (from the notes in firmware 1.5.08), but I am not finding that to be true.
I had my dealer check their Ronin 2 systems as well, and they report the same problem.
Also, my Ronin 2 reports a version of 1.1.0.11 upon installation of the newest firmware, though the DJI Assistant software reports 1.7 is installed (Assistant version 2.02).  Again, the dealer reports the same issue with his units.
Looking to solve this.  Gearing up for Season 2 of a major television series and I'm worried my system won't be as good as last season.
2021-1-15
