Is motor or esc to blame for my mavic pro crash .
649 2 2018-7-29
moss99
Hi all , my mavic crashed a few days ago , i got a motor obstruction warning shortly before it spiraled out of conrtrol ...   apparently the rear left motor stopped , i have done some tests with the motor measuring the ac output volts when spinning it , they are the same,  also same when compared to a good motor , although the motor did feel a bit tighter to turn than the rest . i also checked the resistance with a milliohm meter the windings seemed ok .  Would the esc shut down the motor if it got too hot for example ?  i would have expected a current warning of some kind if this were the case . I have put a link to the flight log .
Flight Log
2018-7-29
DJI Wanda
Hello there. We apologize for what happened. We highly suggest to send it to our repair facility and have it check. You may start a case online: https://repair.dji.com or send an email to support.nl@dji.com.
2018-7-29
moss99
DJI Wanda Posted at 2018-7-29 06:51
Hello there. We apologize for what happened. We highly suggest to send it to our repair facility and have it check. You may start a case online: https://repair.dji.com or send an email to .
Hi , thanks for the reply , but have the drone stripped down on my bench awaiting new parts , just not sure if i should put in a new esc board or not . its not under warranty or anything ..
2018-7-29
