2.4ghz or 5.8?
1069 7 2018-7-29
Just another drone guy
Flight distance : 875499 ft
I recently saw this post about range on a drone then started to wonder how to change between 2.4ghz and 5.8 Can someone please explain what the differences are between these two and which one I should use/is recommeded. also how to change between the two
Thanks
2018-7-29
DJI Stephen
Hi. In general, with no interference, you should do better with 2.4 GHz.  If you are in urban places with more interference, you may very well do better with 5.8 GHz.
2018-7-29
DJI Stephen Posted at 2018-7-29 09:38
is it possible to switch between the two? and if so, how?
2018-7-29
djiuser_CUboEDTJQt8M
Flight distance : 19951 ft
Turkey
bende aynı sikinti var bende 2.4 ve 5.8 arasında geçiş nasıl yapilmalidir yardımcı olursaniz sevinirim tşk
2018-7-29
Jos A
Flight distance : 73209 ft
Your Mavic Rc works only on 2.4 GHZ (occusync).
I think the 5.8 is without controller, on wifi
2018-7-30
Wachtberger
Flight distance : 261509 ft
Just another drone guy Posted at 2018-7-29 10:33
Yes, in the DJI GO 4 menu. In an area with FCC transmission standard I would fly with 5,8 Ghz because this band is much less vulnerable to interference from other WiFi networks and has the same range as 2,4 Ghz.
In Europe however, where the CE standard applies the 5,8 Ghz band is much weaker and therefore significantly reduces the range.
2018-7-30
Wachtberger Posted at 2018-7-30 03:10
ok, thanks for this info ill try to see if I can change it and ill also do research on the fcc transmission standard, thanks!
2018-7-30
LordoftheFlies
Just another drone guy Posted at 2018-7-30 19:00
I have not seen much difference with range at 5.8GhZ. The video signal does tend to be more consistent with 5.8Ghz in urban areas. If you go out of range. It won't make much of a difference.
The safest bet it the use the app video feed as reference and capture the footage straight the drone/card every time. Monitor your wifi, weather, and GPS signals. As always don't fly too far in the city. Or you will be flying blind.
2018-7-30
