Anthony90
Flight distance : 761519 ft
Nigel_ Posted at 2018-8-1 03:06
After the controller is off, no lights left on, it should do nothing for 3 seconds, then it should retrace its route back to where it last had a good signal, then after 30 seconds it should give up and head home. What happens during the 30 seconds depends on what it has been doing previously and is unpredictable unless you do it often enough to learn, and even after the 30 seconds it wont be in a big hurry to come home, so give it at least 40 seconds before you give up hope, and then post the logs to phantomhelp for us to take a look at.
If the setting for what to do on loss of signal is set to return home then it should come home. Fly it out to 100m using a none direct path first - can make the return flight more interesting.
Thanks for your advice, I'll give this a go and see what happens. Ill post the data if its a fail so you can see! |
