HedgeTrimmer
Take your drone to your mining claim, but don't fly it. Instead check compass interference bars under Advance / Sensor State / Compass.
Both Compasses should have short green bars with low numbers. If not, try setting drone about 1-meter off ground on non ferrous stable platform. If ''hot rocks'' were causing interference with Earth's magnetic field, the bars should go green and shorten.
Personally, I would first check area using one of free (or nearly free) Magnetic Field Interference Apps that use your Android or iOS phone's builtin Compass (XYZ field strength detectors). I also would not try to calibrate drone's compasses in that area, unless drone via GO-4 App absolutely says to.
