Any advice on how to access photos and video from a recent flight on the computer? And how to sync images and videos with other iphones that are also logged in to the same account.
The flight record syncs but not the photos and video.
The photos and video clips are not synched, never have been. The real copies of those are on the SD card in the aircraft. You can access them by plugging the aircraft into the computer using a USB cable, but the transfer rate is very slow. You are better off popping the card out and putting it into an adapter then copying the files to your computer.
Geebax Posted at 2018-7-29 21:21
Hi. Thank you for the inquiry. You can remove the SD card on your DJI drone then use an adaptor or a card reader to connect to your PC for you to be able to transfer your footages and pictures.
