HDMI on DJI goggles
5245 4 2018-7-30
Reco J
New Zealand
Hi all
What is the micro usb port on the goggles for? can I plug it into a tv or monitor using a mini to normal hdmi adapter?
Cheers
Rhys
2018-7-30
msinger
Flight distance : 228255 ft
You can use the micro USB port to charge the goggles, install new firmware on the goggles, and/or connect them to the USB port on a DJI remote controller. You'll need to use the HDMI port for an HDMI connection.
2018-7-30
Reco J
New Zealand
Thanks msinger.
  Just wanting to confirm can I hook the hdmi cable that  comes with the goggles to an adapter to run it through an hdmi input on a tv
Cheer Rhys
2018-7-30
DJI Susan
Reco J Posted at 2018-7-30 12:20
Thanks msinger.
Hey Rhys, for the function of the micro USB port on Goggles, please refer 2#. Regarding the HDMI, the Goggles only available to receive the HDMI signal, do not support to output for now, please kindly note and understand.
2018-7-30
VRGIMP
Can anyone confirm whether or not you can run the goggles at 720p 120hz when connected to PC through HDMI?
2019-3-14
