Tips for a new tello
Home / TELLO /
8614 20 2018-7-31
nicled
Philippines
newbie here for my first toy tello. Any tips?
2018-7-31
nicled
Philippines
2018-7-31
RYZE
Super Moderator
China
Good day Nicled, in regard to your concern, hope the following info would assist.
        Fly in an area with less wifi interference.
        Fly in no wind
        Not suggested stretching over limited hight.
        Not suggested flying over water or under weak light
For more info, you might turn to user manual here:
https://dl-cdn.ryzerobotics.com/ ... _Manual_V1.2_EN.pdf
2018-7-31
nicled
Philippines
Thanks. Made a mistake flying it at night and nearly lost it as it went awry. Good thing the blinking light gave its location. I notice it can go maybe 20-30'meters only and is easily swayed by the wind.
2018-7-31
jacksonnai
well for better flight distance and reduce frame skipping you can turn on airplane mode and use a wifi extender
2018-8-1
jacksonnai
nicled Posted at 2018-7-31 19:45
yup don't fly to high as you might lost it cause of the wind
2018-8-1
nicled
Philippines
Is this controller ok for Tello?
2018-8-11
nicled
Philippines
2018-8-11
vzr
Serbia
Always turn on the Aeroplane mode on your phone then turn on wifi for flight
2018-8-21
nicled
Philippines
What's the reason for rhat?
2018-8-22
vzr
Serbia
To prevent phone calls in the middle of the flight?
2018-8-22
vzr
Serbia
Here is the most important tip for all Tello pilots (I guess):
Don't forget to set WiFi password for your drone. Anyone is able to connect to passwordless WiFi, in fact, many smartphones will do so even without knowledge of the owner. The real problem is that Tello allows only single DHCP client, and as soon as 2nd device is connected to Tello WiFi, 1st one will be disconnected and You are in danger of loosing your Tello. Setting password is super-easy, it takes only 30 seconds and it's one-time job.
Additional note: Xiaomi WiFi repeater 2 works with WPA2 WiFi without problem.
2018-9-6
nicled
Philippines
vzr Posted at 2018-9-6 01:43
How do i set password the same way you set password for wifi?  Thanks for the tip man!
2018-9-6
Zefas
Israel
Hello, I have new tello, but I can't able to fly it, the camera is working but he is not going up, the yellow led blinking
2018-9-11
tuba
How many times has someone accessed your Tello's WiFi?
2018-9-19
Vlas
Flight distance : 1398100 ft
Japan
Agree completely. In regards to flights over water I would suggest only to do attempt it once you are very familiar with the drone.  If the optical flow locks onto a ripple you better be prepared to act quickly to get the drone back to shore.
2018-9-19
RYZE
Super Moderator
China
nicled Posted at 2018-9-6 01:56
Good day Nicled, you can refer below to add a password.
1. Connect Tello’s Wifi and launch into Tello APP.
2. Click Setting –Wifi setting – Add password. You would be required to reboot the drone then.
Hope it would help. Have a good time.
2018-9-19
RYZE
Super Moderator
China
Zefas Posted at 2018-9-11 02:52
Hey Zefas, may I know more details like if all the four propellers would spin?
If none of them would spin, please click the "tap fly " on the top left corner in Tello APP.
If some of them wouldn't spin, please refer the image below to check if all the four propellers are installed properly.  If it persists, a detailed description would be appreciated.
2018-9-19
Vlas
Japan
Water is a big one. Definitely avoid flying over it and only when you are quite familiar with the quad.
2018-9-27
Rogue1Tello
vzr Posted at 2018-8-21 20:26
That's a great tip thanks for that one!!!
2018-9-28
Geraldian
Buy another one ;)
2018-10-9
