Wachtberger
Flight distance : 261509 ft
larryc43230 Posted at 2018-7-31 13:24
The tablet I am using may not be on your "approved" list, but it works perfectly fine with my remote control and Mavic Air. My question has nothing to do with DJI GO 4 malfunctioning or crashing, it runs perfectly fine and does what I need it to do. How in the world could an incompatibility change the WORDING of a setting in the app? :-)
With that out of the way, can anyone tell me whether the "Gimbal Start/Stop Buffer" setting mentioned in some tutorial videos is the same as the "Gimbal Pitch Smoothness" setting in the latest version of the app? Is this just a renaming of the same setting from one version of DJI GO 4 to another, or is it a different animal?
So all is well, which is the most important! :-) The wording of menus in DJI GO and DJI GO 4 varies depending on which operating system you have and also which aircraft you fly. My answer to your question is only my best guess that yes, it means the same. The relevant parameter anyway is how fast your gimbal will move when you turn the wheel. For cinematic and smooth footage you should set the value very low. Just play a bit with it and see what suits you best. |
