Another flight - another gimble reset
962 17 2018-7-31
alex_markov
Flight distance : 39244380 ft
Bulgaria
I am used to gimble resets since I both my Mavic back in jun 2017, but it was ones in 2-4 months. Now when the warranty is gone -  in last 4 flights I had 3 resets - 2 times with N/A's and video stopping and one without stopping (see below) - it's frustrating I am losing a minute of my flight waiting for it to settle and luckily it das not happened when in the wood or some other dense place where I can lose my Precious
2018-7-31
dronybaloney
Flight distance : 24897940 ft
Which sd cards are you using?
2018-7-31
dronybaloney
I am using sandisk extreme 32gb. Before i was using 64gb and i often had gimble problems( like doing a reset automatically while in flight) with this sd card. Maybe this has got to do with it.
2018-7-31
alex_markov
Bulgaria
dronybaloney Posted at 2018-7-31 14:22
It very well might be related - my pug eat my Samsung 64GB pro SD and I replaced it with SanDisk Extreme microSDXC 64GB and resets are way more often (not that one did not happened the day before old card destruction )
2018-7-31
rolling56
Flight distance : 138310 ft
Loved the video and know what you mean. I've been thinking about using  NLD apps and just backup my firmware and use both my Mavics like they were meant to from the start and not all the NFZ bull crap stuff etc lol They have capped even us 107 certs and i cannot inspect a tower 2000+ feet high TV towers anymore without jumping through hoops. THAT'what was my final straw.Hope the resets go away with a new SD card.
2018-7-31
dronybaloney
Try using 32 gb sd cards, i am almost sure, you won’t have any resets anymore
2018-7-31
alex_markov
Bulgaria
dronybaloney Posted at 2018-7-31 22:20
I purchased one - soon will try, hope  You are right
2018-7-31
dronybaloney
Let me know
2018-8-1
B1houdini
Flight distance : 927927 ft
Sorry about the reset.
I see it has been a year since you purchased your Mavic.
Looking over mine I see the Gimbal flex cable shifted a little . Not sure if the connector is still seated firmly but was wondering if it did loosen up and flying in the clouds that there might be a moisture issue with the connector.
How could ever  think it might be caused by that cute looking Pug eating the SD card.?
She loves your videos and just wanted to see what was on the card.
2018-8-1
Koelkop
Flight distance : 22814806 ft
South Africa
Mine also does it occasionally. In the video it did it 3 times in one flight, not always that bad and not always every flight. As you can see before it does it it looks like it starts to vibrate.
BUT, with ND filters on I have yet to have it happen. My take on it is that the gimbal starts to vibrate and when it senses that its going out of its set limits it start to reset?! Maybe the little extra weight of the ND filter helps to keep it still. Sometimes I would fly 3 batteries with ND filters on and no resets, and when it gets too dark and I remove the filter I will get a reset.
If you watch the video through youtube the timestamps are in the description
2018-8-1
alex_markov
Bulgaria
Today SD Card arrived (Transcend 32GB MicroSDXC/SDHC Class 10 UHSI U3 633x read: up to 95MB/s write: up to 85MB/s)  and I start testing - 4 batteries (~50 minutes flight time, ~40 km) - No reset with N/S and movie cut, BUT (there's always a but) in the first flight happened what happened 2 months ago https://forum.dji.com/thread-152000-1-1.html something like gimble reset but shorter without clip stopping BUT with direction change - this time smaller than back then and I decided to take a closer look.
So I screen capture flight log put on top of it camera footage and made short documentary
The interesting part was on the third flight it gave me compass error for the first time and continue flying in ATTI mode for good 2 minutes showing no flight path on DJI GO (but recording it!) then recovered and continue normal flight (I was flying all the time as planned )
2018-8-2
alex_markov
Bulgaria
Good call, new SD card (Transcend x633 32GB) is in the Mavic for 11 flights with no resets! Previous SanDisk Extreme microSDXC 64GB was causing nearly Every flight a gimble reset - go figure.
2018-8-6
RadioFlyerMan
Flight distance : 2594032 ft
I have been dealing with gimbal/camera resets also.  I have two cards, 16gig, Sandisk Extreme that came with the Platinum, and a 64gig, Samsung EVO purchased in a flymore.   I have been switching between the two as I heard the 64 may be the problem.  Before I takeoff, I have the GO 4 app format the card.  Also to be sure, I have been doing a lot of firmware update/refresh, and  IMU, Compass, Gimbal calibrations to eliminate those variables.
My experience over the last two month is that all resets happen with the 64gig and never with the 16gig.  Also, it is possible but NOT confirmed that the resets happen when the current load on the battery is high, or maybe a weak video signal.   Now I fly with just the 16gig as it has enough capacity for what I do.
2018-10-29
alex_markov
Bulgaria
RadioFlyerMan Posted at 2018-10-29 08:04
Transcend x633 32GB - 0 resets for monts!
2018-10-29
RadioFlyerMan
alex_markov Posted at 2018-10-29 08:25
I'm not knowlegable regarding these cards.  Thanks for the advice!
2018-10-29
alex_markov
Bulgaria
RadioFlyerMan Posted at 2018-10-29 10:16
Me either, but when decided to try new SD card this one was available and happened to be the keeper
2018-10-29
Evil5
Flight distance : 71060 ft
Sorry, off topic! I just have a simple question but DJI won‘t let me post until I have 10 credit points? DJI, this is highly unprofessional, not customer friendly and definitely not
helping...!
My question: is there a separate serial number for the Mavic pro? If so, where can I find it? And please don’t go with „Why doch you need it?“, ok? I simply need to know. Thanks.
2019-1-7
Evil5
Evil5 Posted at 1-7 06:10
helping...!
I meant a CAMERA serial, sorry - forgot to mention. ;)
2019-1-7
