iPad Air - Overheating Problems
451 14 2018-7-31
eze.lasvegas
Flight distance : 58914 ft
Just an FYI, I have a new Phantom 4 and use it with an iPad AIR (V1).  Since I live in Vegas, during this time of year, it gets wicked hot.  I noticed that after 15-20 minutes of flying, my Video transmission would become unstable, yet no warnings.  I determined this was being caused by the iPad getting hot.  Put a cold med wrap on it and resolved the problem.  I have also seen that it can cause some interference with the Antenna and thus, put some Farady Tape behind it to make sure the iPad RF was blocked between the Antenna.  Just sharing some OJT Tech Tips.  There are some great places to fly out here.
2018-7-31
DJI Natalia
Hi. I'm sorry for the inconvenience and the trouble that this caused you. I recommend you to avoid direct sunlight to your iPad when flying your drone to avoid overheating. You can also use a remote controller hood to protect your iPad from sunlight. You can check this link for reference. https://store.dji.com/product-search?q=hood. Thank you.
2018-7-31
eze.lasvegas
DJI Natalia Posted at 2018-7-31 13:42
Thanks for the info.  I do have a hood, but it's basically the crazy heat here.  I proved this the other evening when I was chasing the back end of a storm in the desert that dropped the temperature 20 degrees for an hour.  The chill packs work pretty well and I have to take a cooler along for water anyway.  It's just the nature of the beast.  I'm in IT and know what heat does to things.  Since I'm somewhat of a newbie to the Phantom 4, I just had to get out and fly.  I just wanted to make sure others who might have experienced this, since it is Summer, they might have some insight.
2018-7-31
Michael Kemper
Flight distance : 596204 ft
I've experienced this same issue here in Phoenix but with my iPad mini. My iPad 10.5 doesn't seem to have the same issue in the same heat. What temperatures are you experiencing this in?
2018-7-31
Pens Fan
Flight distance : 22113 ft
Ha ha, I don't me to laugh but this just happened to my buddy in FLA. He was 1/4 mile out in the Keys at about 350ft altitude and his iPad shut off! He was freaking out. He said that he was able to use his iPhone and connect to it and bring it back. Whew!
2018-7-31
RedHotPoker
Flight distance : 165105 ft
My iPad Air2 Cellular only heats up if left in the direct sun...
RedHotPoker
2018-7-31
eze.lasvegas
HOMEMADE RESOLUTION TO OVERHEATING TABLETS
This only works for Phantom 4 & Phantom 3 Pro and will resolve overheating of a tablet.
It will resolve overheating which results in inconsistant display, yet not receiving any Video Transmission Errors.
Its a V1 prototype, but here it is.  To me, I think there might be a better way to hold the Gel Pack so you can have more of a professional look to the whole thing, but I really needed to do proof of concept and prove this was causing the video problems.
Materials purchased from Amazon
Controller Sunshade $12.00
https://www.amazon.com/gp/product/B076X3L49S/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
Small Gel Packs $5.00
https://www.amazon.com/gp/product/B00AZ72MAE/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
10" Padded Envelope Cut to Size and open on one end to insert the Gel Pack
I also put some Farady Tape on the back of the iPad to prevent interference with the Antenna.
Here is the link: https://www.amazon.com/gp/product/B07CRLCGCH/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
I also make sure to turn OFF WIFI and BLUETOOTH on both the iPad and my Phone while flying.
Components
Components
Gel Pack into Envelope
Finished Result
Finished Result
2018-8-1
eze.lasvegas
Michael Kemper Posted at 2018-7-31 18:05
100 ish at Sunset using iPad Air V1 with cover, but just too much heat.  I believe the GPU is working too hard and thus causing the excessive heat.  Heat is the enemy of all electronics.
2018-8-1
eze.lasvegas
2018-8-1
eze.lasvegas
I also forgot to mention that since now the iPad runs much cooler, no video transmission errors and battery life is back to normal.  Battery would also get used up faster with the heat.
2018-8-1
eze.lasvegas
You can strap the Gel Pack directly to the back, I just wanted to have one level of non-direct cooling and basically a moisture barrier.
2018-8-1
iVENOM
India
IF you want to check the heating of the app then you need to watch movies and tv shows to uncover the truth. You can watch Free movies and Netflix shows on Terrarium Tv app.
You can also download the app on your device to watch on the go. Download Terrarium Tv apk to watch movies on the go
2018-8-4
eze.lasvegas
So to take this up a notch.  I purchased a hard shell iPad case and removed the flip front cover, purchased at Amazon for $10.00 https://www.amazon.com/gp/produc ... 1_s01?ie=UTF8&psc=1
Then purchased a black pouch for another $6.00 https://www.amazon.com/gp/produc ... 1_s00?ie=UTF8&psc=1 and here are some pics of the final assembly. including the Farady tape on the inside of the iPad shell.
Now it all fits perfect, looks clean and is a tight fit.  We all like a tight fit, don't we?
2018-8-4
eze.lasvegas
2018-8-4
eze.lasvegas
2018-8-4
