hallmark007
Flight distance : 9827923 ft
11 is a good safe number, it was always recommended RC , Aircraft then app, in good signal areas gps should kick in at about 60 seconds, when changing battery it should be a lot quicker. Once your gps kicks in anything from 6 to 11 your Aircraft will register homepoint, although we don’t see or hear this until Aircraft has taken off.
3/4 minutes seems inordinately long in good areas not covered by trees etc, when starting Aircraft try to avoid blocking signal by covering top of Aircraft with your hand, this might help. |
