Mark The Droner
Flight distance : 2917 ft
fansbb14b570 Posted at 2018-8-2 05:42
Thanks for your input, I appreciate the help. Have you ever requested a Custom Unlock? I'm wondering if I can just write a .pdf and have the airport manager sign it.
"2. Include authorization documents indicating the area your team is authorized to fly in and by whom. Documentation may differ depending on the type of the restricted zone:
No, I have not.
The irony is, you don't need permission to fly, now that I think about it. Re the airport, if you're 101, you just need to notify and if you're 107, it's Class G airspace so you don't need clearance. Re the TFR, there's no TFR until later this evening, and even then, you're not flying in it anyway.
So, I guess you need to somehow convince them that they have restricted your flight in an area where you are already perfectly authorized to fly due to the starting time of the TFR and also due to the cut-out of the TFR. I'm sure it's frustrating. But you should focus on the TFR because that's where the problem lies. The airport has nothing to do with DJI's restriction, other than your need to self-unlock the yellow zone of that airport which is normally a piece of cake.
Please report back here and tell us how it works out.
Good luck.
