Labroides
Flight distance : 9991457 ft
DJIJAKOB Posted at 2018-8-2 01:13
Hi ImaneFadir! In shorts terms; the V2.0 has an upgraded video transmission system called OcuSync. The same system which is used for Mavic Pro. It also has upgraded ESC's and propellers, which gives the drone an estimated 60% noise reduction. And the newest Exmor R CMOS sensor.
The V2.0 uses the same camera and sensor as the previous version.
From the V2.0 FAQ https://www.dji.com/phantom-4-pro-v2/info#faq
1.What are the main similarities and differences between the Phantom 4 Pro V2.0 and Phantom 4 Pro?
The Phantom 4 Pro V2.0 uses the same camera as the Phantom 4 Pro and is equipped with a 1-inch 20-megapixel sensor capable of shooting 4K/60fps video at 100Mbps. Also, like the Phantom 4 Pro, V2.0 features a 30-minute maximum flight time and 7-kilometer long-range control. The remote controller of the Phantom 4 Pro V2.0 also supports 2.4 and 5.8GHz frequency switching, and a remote controller a with built-in screen is also available. Different from the Phantom 4 Pro, the Phantom 4 Pro V2.0 is equipped with an OcuSync transmission system, which allows the drone to connect to DJI Goggles wirelessly. The Phantom 4 Pro V2.0 also features an upgraded propulsion system with FOC sinusoidal driver ESCs and 9455S quick-release propellers that reduce noise and make the drone more aerodynamic. *The remote controller of Phantom 4 Pro V2.0 is not compatible with the Phantom 4 Pro, which uses Lightbridge transmission. Other accessories such as batteries, chargers, and ND filters are compatible with both the Phantom 4 Pro and Phantom 4 Pro V2.0. |
