GMPt
Also, I have another question to add to this about the behaviour of the autopilot.
It seems that there something unexpected happening when switching between modes P and M. when on the ground without the rotors I arm the motors in the GPS Atti (P) mode and switch to the manual (M) mode the throttle stick seems to be still operating as the rate of climb, however, if I arm the motors in the manual mode, then the throttle stick behaves as throttle stick as I believe it should. If I arm the motors in the manual mode I can switch to any mode and back to manual mode without a problem i.e the throttle is still the throttle. If I arm in GPS atti no matter how many times I switch to manual mode an back, it still feels that the throttle stick controls the rate of climb/descend.
I guess the question would be Is this behaviour normal? |
