Mark The Droner
Flight distance : 2917 ft
What country are you located?
You say you have an "extender." That covers a broad range of devices and equipment. Can you be more specific?
You say you have range problems over open water. Are you saying you don't have range problems over open land?
You won't be able to tell anything by looking at the app other than signal strength and the indicator is not fine enough to see a difference. You'd need an EMF meter to see the difference. And it's not worth the money. But you do need to learn how to aim the antennas.
You seem to have an SE, so assuming that is correct...
Your working antennas are patch antennas hidden inside the controller. If your controller is horizontal, the best signal is shooting straight forwards. So tilt and aim the controller at the AC that way. Forget about the stick antenna - it just communicates with your mobile device. Still - you'd probably want to point it up towards the sky so it doesn't look dumb.
Good luck.
