Helmer Baas
Hi droners,
I have a Mavic Air, flown over 150km's with it but I keep having trouble every other time. In the exact some place (wide open field), exact same conditions (sunny, no wind) sometimes I have no problem at all, sometimes I cant hardly do anything. The Mavic Air is in FCC mode.
Without problems I can fly over 1000 meters, signal is quite stable, typically the connection is on 5.8Ghz.
A day later, I won't be able to fly because I will lose connection every three seconds. When I disconnect the cable and reconnect again, signal will return again for a few seconds. Frequency will switch between 2.4 and 5.8 all the time, even though it is set to custom 5.8Ghz.
I have tried a new cable, I have reinstalled the app, turned on flight mode, refreshed the firmware on Mavic air and controller, turned on USB debug mode. I am out of options.
Anybody has any clue what I try to fix this? It is really really frustrating that half the time I am not able to fly at all, whilst another time it works perfectly.
Thanks!!
