Nigel_
Flight distance : 388642 ft
rwynant V1 Posted at 2018-8-5 16:37
Nigel,
The cell readings......yes, I have seen at least 1 other thread where the cells across the board stayed exactly the same for over 6 minutes until the AC crashed.....I don't know which thread, but Labroides was in it.......but he's in ALL the threads
On this one, if you plot a graph of cell voltage over time then it is increasing as the battery empties, with a corresponding reduction in current. Voltage does drop when the throttle is pushed up so all appears correct except that battery voltage is supposed to drop as the battery empties and instead it is increasing! There is also a puzzling reduction in voltage difference between cells over time, which should be an increase.
It's not really credible that the voltages reported are correct, maybe there is a calibration in there that has got screwed up...
Would be interesting to see if the other thread is the same, but searching for threads with Labroides posts in them isn't going to help find it
