Already fearful of DJI's build and QA reputation..
Just unboxed and built my new Ronin-M and already have an issue. The bolts that secure the handgrips to the arms dont seem to be long enough. Barely bite into the metal, one side only just the other is clearly not long enough. In the factory they wont see the problem as they just put the bolts into the grips and pack them but once you undo them enough to fit them on the arms theres no doing them up again. Hopefully DJI will just post me out some replacements.. but based on my first sentence...not holding my breath.
Same issue, moreover, the thread diamiter is slightly larger inside the loose handle bar. I bought longer screw of same thread from a hardware store and it still doesn't thread correctly. I ended up bolting both handle bars with longer screws, as dji hasn't fixed this issue nor will it.
Also a bit disappointed the PROPER inverted mode i tried at NAB has been hobbled with this annoying 'camera upside down' only mode of inverted. but hey. get what you pay for
i think the handgrip is not threaded properly. the thread is too large for the bolt and its simply doesnt grip. I need a new handgrip and bolt please!
also 3 days now and no reply from tech support. Not a good start people. Your reputation preceeds you though so im not expecting much
Time to lift the game though people
Ok i have emailed this video of the fault to you as requested and have posted it below Im sure it is the same issue other users such as DaVePI had posted about
